105 hb -- 115 hb hangisii
  • Konuyu Başlatan Konuyu Başlatan airbus
10 HP iyi bir fark bana göre..tabiki 115 hp.Üstelik motor farkıda var.Biri twinport biri ecotec...
opel (115 hp) 1.6i 16v VVT Ecotec
Engine Specification
Engine, location Front, transverse, 7 50'; forward inclined
Cooling system Liquid, sealed circuit
Cylinders, number 4
Bore (mm) 79
Stroke (mm) 81.5
Displacement (cc) 1598
Compression ratio 10.8 : 1
Engine, type In line; 5 main bearings
Cylinder
block/ head
material Cast iron / aluminium
Camshaft(s),
location 2 overhead (DOHC), driven by toothed belt
Valve train Bucket tappets
Valve, arrangement v; 4 per cylinder; variable valve timing
Valve, adjustment Mechanical
Fuel system Sequential multi point fuel injection
Ignition system Electronic ignition map (EST) + Knock Sensor
Fuel pump Electric, in tank
Emission control
system Cat. conv. with 2 oxygen sensors
Output
(kW/hp CEE at 1/min) 85 / 115 at 6000
Specific power
(kW/l; hp/l) 53.2; 72.3
Max. torque
(Nm at 1/min) 155 at 4000
Specific torque
(Nm/litre) 97
Mean effective pressure at max. power/ max. torque
(Nm/litre) 1064 / 1219
Average piston
speed (m/s) 16.3
Engine oil,
capacity (l) 4.5
Cooling capacity (l) 6.9
Battery 12V,
capacity (Ah) 44
Alternator 14.2V,
capacity (W) tba
Max. service interval 20,000 miles or 1 year
Emission compliance Euro 4
105hp arabana chip takınca 10hp yükseldiğinde çok fark eder ama;)bu da yabana atılmamalı bence..zaten artık twinport üretilmiyo 2008lerde
hepsı ecotec yeni nesil:)
arkadaşlar twinport motorlarda ecotec'dir.ama tabiki 115 hp.daha iyi olur.şuda bir gerçek 115 hp bile bence artık az adamlar 125-130 hp lerde takılıyorlar opel 105-115 hp'lerde.
Sanırım 2008 modeller 116 hp...
Sizin ruhsatta BG olarak mı yazıyor?? Benim ruhsatta kW olarak yazıyor. Ona da 85 kW diye yazmışlar, HP'ye çevirirsek 114 BG eder.
