X3 ile yakıt tüketimim...
Ynt: X3 ile yakıt tüketimim...
astraowner link' Alıntı:
mercedes a serisindeki motorlar psa olması lazım 116d deki motor bmw motoru yanlış hatırlamıyorsam.
Mercedes Renault un 1.5 dCi motorunu kullanıyor, tabı bazı teknik aksamları farklı.
Bunun dışında Renault un 1.6 130 ve yeni 1.6 160Hp lik dizelini de alacak.
''The PSA Group sells a variety of diesel automobile engines with the HDi (high-pressure direct injection) designation. Earlier versions were exclusive to Peugeot and CitroÖ«n. In 1998, PSA entered into a joint venture with the Ford Motor Company to produce a range of new diesel engines. The joint venture makes identical engines which are fitted to a variety of vehicles from a range of car manufacturers. The engines are assembled in production plants in the cities of TrÖ©mery and Douvrin for PSA in France, at the Ford Dagenham plant in England, and the Ford-owned Volvo Engine Plant in Skövde Sweden.
Half of the group's vehicles are fitted with an HDi diesel engine: in 2007 this amounted to approximately 1.8 million vehicles.
As a result of a cooperation between BMW Group and PSA, the MINI One D and the MINI Cooper D are also fitted with PSA-made HDi DV engines.[1]
The 1.6 L (1,560 cc) Diesel is part of the DV/DLD family and is, depending application, called the DV6 (PSA), W16 (MINI) or DLD-416 (Ford). 90 PS and 110 PS versions are available. Though both intercooled, the major difference being that the 90 PS has a conventional waste-gated Mitsubishi MHI TD025 turbo charger, whilst the 110 PS uses a Garret GT15V variable geometry (VNT) turbocharger. The 110 PS version of this engine can be ordered in an unprecedented variety of car models, representing either side of the motoring spectrum, ranging from the MINI Cooper D to the Volvo S80 1.6D DRIVe. From 2011 PSA start to develop (1,598 cc) diesel with BMW/Mini
Böyle de bir bilgi var ama...   ::)
Mercedes Renault'un dci motorunu kullanıyor bu arada.
gradient link' Alıntı:
Abi bu konular aslında biraz daha karışık, Bmw ve Psa ile başka adını çoğumuzun duymadığı motor üreticileri işbirliği yapıyorlar, Bmw kendi araçlarına uygun olanları alıp kendi teknolojisi ile geliştirip araçlarına adapte ediyor.
