Evet F fan club olduğumuza göre araçlarımızın teknik özelliklerini yazalım öle değilmi
MakeOpel
ModelAstra 1.6 16V Saloon
Production
FamilyChassis and DimensionsChassis Type4/5S SAL
Number of Doors4
Wheelbase2606 mm (102.6 in)
Front Track1464 mm (57.6 in)
Rear Track1452 mm (57.2 in)
Length4252 mm (167.4 in)
Width1709 mm (67.3 in)
Height1425 mm (56.1 in)
Ground ClearanceLength / Wheelbase Ratio1.63
Weight1205 kg (2654.2 lb)
Weight Distribution (front/rear)Fuel Capacity52 litre (11.4 Imp gal , 13.7 US gal)
AerodynamicsDrag Coefficient0.28
Frontal Area2.06
Cx0.58
Engine SpecificationsEngine ManufacturerOpel
Engine LocationFront
Engine AlignmentTransverse
Engine ConstructionCoolant TypeWater
Engine TypeDOHC
Number of Cylinders and PlacementS-4
Valves per Cylinder4 (total 16)
Engine Displacement1598 cc (97.52 cu in)
Bore79 mm (3.11 in)
Stroke81.5 mm (3.21 in)
Bore / Stroke Ratio0.97
Unitary Capacity399.5 cc/cylinder (24.38 cu in/cylinder
Number of Main BearingsCompression Ratio10.5 : 1
Fuel System TypeSFi
Aspiration TypeNormal
Compressor Type-
Intercooler TypeNone
Catalytic ConverterYes
Maximum Engine Power101 HP (75.3 kW)
Maximum Engine Power rpm6000 d/d
Maximum Engine Torque150 N.m (110.7 lb.ft , 15.3 kg.m)
Maximum Engine Torque rpm3600 d/d
Engine Torque at Max. Engine Power rpm119.9 N.m (6000 d/d)
Power / Weight Ratio83.8 HP/ton (62.5 W/kg)
Power / Engine Displacement Ratio63.2 HP/litre (47.1 kW/litre)
CO2 EmissionsFuel ConsumptionPerformance
0 - 80 km/h0 - 60 mph0 - 100 km/h11.5 s
0 - 160 km/h80 - 120 km/h (in top gear)0 - 400 m Acceleration0 - 1000 m AccelerationTop Speed188 km/h (116.8 mph)
Gearbox and TransmissionTransmission
Type5M
Top Gear Ratio0.89 : 1
Final Drive Ratio3.74 : 1
Drive WheelsFWD
Handling, Suspension Geometry and BrakesSteering TypeSteering Turns (lock to lock)Turning Circle DiameterSuspension (front)Suspension (rear)Brakes (front/rear)Di/Di-S-ABS
Brake Disc Diameter (front)Brake Disc Diameter (rear)Wheels (front)Wheels (rear)Tyres (front)Tyres (rear)
BİDE ŞU ÖZELLİĞİN TÜRKÇESİ OLSA DAHA GÜZEL OLACAK
Ayrıca Celaleddin abi teşekkürler teknik servise açtığım topic sayesinde öğrenebildim
