Ynt: active select güncelleme
valla ustaya neden haber vermediniz diye sorduğumda yazılımın daha 1-2 ay önce geldiğini söyledim ,bu arada 1.6T ve 1.4T nin şanzıman kodu aynı 6t 40 şanzıman aşağıda teknik özelliklerini paylaşıyorum
Hydra-Matic 6T40 (MH8)
Type: Six speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with an electronically controlled torque converter clutch.
Maximum Engine power
hp/kW ) 180 hp ( 134 kW )
Maximum engine torque: 177 lb-ft (240 Nm)
Maximum gearbox torque: 277 lb-ft (375 Nm) - All gears
Gear ratios: MH8
First:4.58
Second: 2.96
Third: 1.91
Fourth: 1.45
Fifth: 1.00
Sixth: 0.75
Reverse: 2.94
Final Drive Ratio: 3.87
Maximum input speed: Rev 4000 rpm
1-2 7000 rpm
2-3 7000 rpm
3-4 7000 rpm
4-5 7000 rpm
5-6 6000 rpm (corresponds to 4476 rpm in 6th after the shift is complete)
Maximum input speed in 6th: 4476 rpm
Maximum validated gross vehicle weight: 1996 kg (4400 lbs)
Shifter Posistions: P, R, N, D, M
Case material: die cast aluminum
Shift pattern: Variable Flow Solenoids
Shift quality: Variable Flow Solenoids
Torque converter clutch: Variable Bleed Solenoid
Converter size: 236mm (reference) (diameter of torque converter turbine)
Fluid type: DEXRON® VI
Transmission weight: wet: 82 kg (180.4 lb)
Fluid capacity (approximate): 7.77L (6.56 kg)
Bottom pan removal: NA
Pressure taps available: Line Pressure
Transfer design: Two-axis design, Output Chain
Assembly sites: GMK (Korea), SGM (China), SLP (Mexico), TTO (Toledo).
Applications: Chevrolet Malibu & Cruze, Buick Regal & Verano
